450 Pro ESC location
  • 450 Pro ESC location
    So my build is slowly coming along and I now have to decide where to mount the ESC, initial thoughts were to sit it between the frames thus benefiting it from the main gear cooling breeze. 2nd though was to mount it to the side frame either inside or outside the frame.
    Any thoughts? where have you mounted yours?
    Planning to mount the Rx on the underside of the battery mount tray (I have the KDE extended tray fitted).
    Futaba 9CP & 10CG
    mines under the battery tray
    adieuk
    x7 eddie gold stars!
    www.eaglerc.co.uk
    dx7, phoenix sim
      Considered this, will look at it again but thought the cooling would be most poor in that location... not that it should be an issue if the heatsink on the ESC is correctly spec'd
      Futaba 9CP & 10CG
        I am about to get a 450SE going and thinking about this as well.
        Is there any concern about having the RX close to the motor or is that not an issue with 2.4ghz systems?
        I kinda like the idea of having the RX up front either on the lower tray or upside down under the battery tray and then having the ESC either in the middle of the frames or on one side.
          Under ze battery tray for me, might have to move it when the weather gets hotter.
            under teh battery tray. for a couple of reasons.
            1. its electrically close to the battery
            2. its as far away from the RX as you can get
            3. velcro straps hold the ESC and battery in place
            4. it looks tidy.
            5. theres quite a bit of airflow in there due to the fan in the main gear.
            6 if you have teh KDE tray get it in thermal contact with it it will loose more heat
            Steve
            Steve...
            Outrage RC Field Rep
              it was already there m8 and not had the time to move it yet
              adieuk
              www.eaglerc.co.uk
              dx7, phoenix sim
                [QUOTE=xygax;430670]under teh battery tray. for a couple of reasons.
                true, lower losses from the wiring can only be a good thing
                again a good thing and was something of a concern having the Rx close to the motor
                4. it looks tidy
                wasnt expecting this TBH
                that is a good idea but I am not sure if this would be workable without removing the heat sink from the ESC and thermal gluing the ESC to the KDE alu mount.
                Futaba 9CP & 10CG
                  You wont have any issues with under the tray at all regardless of weather it wont get that hot all my aligns E helis are under the tray affairs no issues.
                  The biggest bonus missing is CG move it away from under tray and you will have a head ache TT helis tail heavy at the best of times.
                  With an alu battery mount you shouldn't have to glue it just have it contact and it will act as a huge heat sink.
                  Alex
                  Innovation RC Blog
                  Innovation-Rc on eBay
                  www.heliharry.co.uk
                  www.robochallenge.co.uk
                  500 ESP. Ely Q Comp, KASAMA'd 600
                    Under battery tray...!!!
                    TREX 600 pro V-BAR
                    TREX 500 V-BAR
                    DFC
                    BLADE 130x
                    DX7
                    PHOENIX
                      OK it seems everyone says mount the ESC under the battery tray. So what about the RX?
                        AR6100e turned upside down so the pick up can stick outside the frames without chaffing..
                        TREX 600 pro V-BAR
                        TREX 500 V-BAR
                        DFC
                        BLADE 130x
                        DX7
                        PHOENIX
                          My Esc is strapped on the side, no rx any more as I am using a mini Vbar
                            Bloody show off
                            Alex
                            Innovation RC Blog
                            www.heliharry.co.uk
                              Where did you decide, Rob?
                              Martin
