Yeah with 450s there's only so much you can do as they're subject to being blown around a bit regardless. In general if the flybar is too heavy the result is the heli will get blown with the wind, if the flybar is too light it will 'over correct' and the heli will try to move into the wind, so there's an ideal weight where it stays put pretty much. This will be different depending on the flybar ratio etc.
I still have a Beam E4 original flybarred version and the head geometry is a bit different so that it works with lighter paddles and if I were to use the same weights I used on the Trex it would be way too heavy and sluggish.
I kinda drifted away from 450s in general over the years but earlier this year I got a very nice 2nd hand Beam E4 SE (DFC style FBL head) so I'm going to try building up a FBL 450 and see just how stable it can be and if I like flying it I'll start taking it with me along with whatever else I'm flying on a given day. (I thought about stretching it using a G5 boom I have BTW but I think for the moment I'll try it in original size, 325mm blades first).
