A little tip - the holes that I've put the servo wires through are only big enough for one servo plug.
To get both wires through on the side that has the elevator servo, you'll have to remove one of the servo plugs, push the wire through and re- attach it on the other side.
The esc wire runs through the little hole on the tray and then along the frame just below the main gear
I found the wiring actually quite easy to be honest! Easier than my 450v2 anyway!
