What's the difference ?
  • What's the difference ?
    Hi guys , I was thinking of getting a kit and doing my own build , while looking I'm faced with not knowing the difference between 450 v2 and a 450 SE v2 , could any tell me what the SE may stands for ?
    Many thanks
    ouchie
    The sev2 is discontinued, it was belt drive and had stacked frames.
      Okay cheers !
        I'm guessing "SE"
        Current kit
        Evo 50
        T-rex 500FG night setup.
        T-rex 700N pro
        T-rex 450 pro
        10CP
        Frankenstarter (dynatron)
          So in all fairness the 450 v2 is the one to go for as parts are available etc etc ?
            The v2 is a pro. It has a one set of frames (very strong) tt driven tail. The cyclic servos are 'direct to swash' and the tail servo now sits I between the frames as opposed to on the boom as the se was. It's a cracking little Heli, cheap to crash and spares are easily sourced
              Cheers don that has cleared a lot up for me , but on the v2 I'm looking at the tail servo still is on the tail boom , it's only a cheap kit of eBay tho as I don't want to spend to much just yet !
                Post a link, cheap is often a false economy fella
                  Look at this on eBay:
                  ARF Carbon Helicopter Metal Upgrade Trex 450 V2 RC KIT
                  http://bit.ly/16LzD6w
                    I started out down that road after ignoring my mate's advice and after the head flew apart (made from cream cheese...) and the tail disintegrated (even softer cream cheese...) and half the screw heads rounded off as they were made out of butter.....I replaced with pucker Align components (some second hand) so that the only things left of the original are the metal frames and the skids (which are brilliant as they're so soft and bouncy that they don't break!!)
                    Before anyone has a go at me for being too negative....you can be lucky and get a good one but it's a bit of a lottery. You can go the cheap route quite happily but more often than not you end up chasing problems. In my opinion you're better off buying a second hand real Align off here with better quality components in than buying cheap new equipment.
                    Neil
                    1 x
                    Raptor 30, OS32, on its way to being FBL (and leccy?)
                    Trex 450 Pro, Beastx, Savox 0257, DS520
                    Blade 180CFX
                    DX9 & DX7
                    Too many planks...
                      You would be better with something like this if you choose the cheap seats
                      http://www.hobbyking.com/mobile/view...dparentcat=111
                      Better clones are Tarot but they are a bit dearer, they are good quality for a clone
                        Okay i think my mind is made up to go with a real Align 450 as I can see me spending more money on crap than getting into the air
                        cheers every one !
                          Good call
                            cheers every one !
                            Good decision imo!
                            Stainburn Helicopter Club
                            Sab Goblin Black Nitro 650
                            MSH Protos 380
                            Vbar Control
                              I made the mistake on going for a HK clown , looking at it now its only the frame left everything else is align parts .... Go with the align from day one !
                              Sent from my iPad using Tapatalk HD
                              Nano CPX, 2 x blade 300x, blade 450 (sk720 FBL), align250
