I'm fed up with the unexpected tail blowouts on my 250 & you never know when its going to do it, I've used Vbar, Beastx, Gpro so feeling poorly over the weekend gave me a chance to have a good internet search for options & found a few others have opted for the MKs DS95i & reports of rock solid tail so ive got one being delivered tomorrow but undecided which fbl unit to use..? at the moment the Gpro is back on it but simple enough to swap
This alt to do it, MKs DS95i
Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
- Flickr Through My Pictures.
Tags: None
I have had a DS95 as a tail servo with two 450s and the speed is amazing. Even ages ago on a Trex 450 SE with a GY401 gyro the holding power was remarkable.Kasama, Minicopter, Henseleit, JR, Shape, Beam
Proud recipient of 7 EGS!
and a platinum star
Never thought about my 450, not that I have an issue but saying that it's not brilliant so if it works on my 250 defo get one for 450.Originally posted by trillian View PostI have had a DS95 as a tail servo with two 450s and the speed is amazing. Even ages ago on a Trex 450 SE with a GY401 gyro the holding power was remarkable.Last edited by tourerjim; 04-05-2016, 07:12 AM.Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
Vbar is now on......Originally posted by GIXERMAN View Postjr 3500g was a good servo for 250 also. in my opinion would put vbar on off the controllers mentioned.Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
With that tail servo you'll probably find that all the FBL units hold the tail pretty darn well now. On the vBar don't forget that there's a tail setting for micro models, that seems to work well on the 250.Helis: Oxy 2 FE / Oxy 2 Sport / Protos 380 / Oxy 4 Max / Gaui X3 380mm
Electronics: Spartan VX1e / Spartan VX1n / Spartan VX1p / MSH Brain2 mini / Jeti DS-14
Sims: Realflight / AccuRC / Phoenix RC (Wireless) | AccuRC (Wireless) | Realflight (Wireless)
DS95. It's more than capable.Originally posted by scallybert View PostDS95 or DS95i ..?Kasama, Minicopter, Henseleit, JR, Shape, Beam
and a platinum star
She's all setup now with the DS95i so with a bit of luck I might get a chance to fly her tomorrow.Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
Strange problem, im sure i checked everything was working fine last night got to the field this eve & the right cyclic servos not working with the Vbar, shot back home to plug into the pc & all the setting are correct so that's very odd anyhow desperate to want to fly it I quickly fitted the Gpro then back to the field & had 6 awesome flights with the new tail servo its amazingly solid control, now back home ive just swapped back to the Vbar & same servo won't work, anyone with ideas why...?Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
Align swash servos ?
I've seen this happen on T-Rex 450s [DS4xx] and 500s [DS5xx] with Skookums
It's like the servos don't initialise correctly, and strangely, it's often the R/H one.
I usually found that powering up again worked - but you maybe are seeing something different.
Sometimes it seemed related to which BEC was used.
In my case, I switched to MKS swash servos.Yes, it's th@ tw@ Scallyb@...
or just use the gpro which seems to be good?Spektrum IX12
Blade Inductrix
T-Rex 150X
T-Rex 450L, Heli Option Turn-buckles, carbon push rod, 6s, Stock Electrics, Giant Power Lipos
Goblin 380 Kyle Stacy, 360mm, 6s, AR7210BX, Align 430m/525m @ 6.0v, Castle Talon 90, Scorpion 3020-1000, Optipower 2700 30c
Goblin 570 Carbon Red, Stretched to 600mm, Blackline 3D Blades, 12s, BD 3SX, Align 800/850 HV servos @ 8.0v Castle 120 Phoenix Edge HV, Scorpion, Thunderpower G8s
T-Rex 800e Pro DFC, Hobbywing 200A, 760x Head, BeastX
As ScallyBert says, you can sometimes get a servo fail to initialise if enough current doesn't come through during the boot up phase. If you unplug the LIPO, then plug it in again - does it work then?Tom
In my case, I switched to MKS swash servos.I must of plugged unplugged power at least a dozen times & each time wouldn't work, what im going to do is enjoy the weekend with the Gpro on it & then in the week swap to the Vbar & try it again.Originally posted by tomatwalden View PostAs ScallyBert says, you can sometimes get a servo fail to initialise if enough current doesn't come through during the boot up phase. If you unplug the LIPO, then plug it in again - does it work then?Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
