600E Pro one-way bearing problems !!
  • 600E Pro one-way bearing problems !!
    Ive had this model 6 month months or so now and my 4th one-way bearing ! Ok Align... what can expect you may say, but i'm a precision engineer by trade and cant work out whether its bad tolerances or design as they don't seem to be a press fit, more stuck in and size wise the bearing holders (i have 3) are all over the place . I think they should be a good old fashioned interference fit .05 mm as perhaps the glue fit allow the cams to expand the outer bearing case. Any one know the reasoning behind this or it Just " Align" ?
    700 Nitro Beastx V3 RL100H installed awaiting pipe
    600 PRO EFL
    Beastx V3
    Velocity 50N Beastx V3
    Trex 600E test machine
    Gaui 200
    I haven't had any problem with mine except when I crashed it. The bearing had to be replaced. I can't understand how they work though.
      Had problems with my 600N with the new type bearing case and OWB.
      Replaced once but now ordered an upgraded Boca bearing to fit and try.
      HF1216 | Boca Bearings - Boca Raton, FL
      Blade mCPX - now Version 2
        I had the same on my 600n with the new style bearing case. Rather than buying a new one I packed Teflon grease into the bearing and no problems since.
        Goblin 380 with Spirit FBL
          Hi,
          I am having the same issue with my 550e, tried 3 bearings now.
          Did you get this beaing yet, any better?
          John
          http://www.thurrockmfc.co.uk/
            Yeah John
            Fitted it and put half a gallon through the YS60 and Rex600 at the weekend.No problems with it locking up but sometimes it sounds a little bit noisy.
            Maybe I need to get some more grease in there.
              Ok, thanks.
              I'll give it a go myself and see how I get on.
              John
                Yeah,worth a go I think.
                A tight fit to get the OWB into the case though and had to use a bench vice and socket to press it in.
                  Time to sweet talk the father in law then!
                    Yeah John
                    Watch the nitros , sometimes it the one way bearing in the clutch. Way to tell if trying to start engine , and feels like it grappin slightly.
                    Santander Factory Team
                    Proud wearer of 5 x EGS
