Swash play
  • Swash play
    Further to my post of a T-Rex 500 swash with play, here's the video (How exciting!)
    http://www.rcheliaddict.co.uk/videos...b3695e0cb6cde7
    The blades are tucked back into the caddy. The flybar moves about 5mm (loose play) and can be be moved (gently) over about 10mm.
    Play can be clearly seen in the swash. The play is actually in the bearing in the lower, larger diameter part of the swash. The play can be seen in the undeside of the swash too between the races of the bearing.
    All the people who said thier swash is play free, how does this compare to yours??
    Thanks.
    Cheers, Lee.
    Proud recipient of an EGS
    Actually that is really bad Leebert. You need to get that returned back the supplier as a new heli should have little or no play. That amount will really affect the way the heli flies.
    In fact neither my 600N or Knights or TREX450 have any up and down play to speak of.
    Slow Mo Blade 550x
      sounds like they sold you a Shuttle one.......
      And a DX8 too
        my 450se v2 is exactly like that, and when i compared it to a brand new one the other day its a lot worst, yet mine has only done approx 50 flights or so.
        as yours is brand new bert id contact either bobj or the shop you got it from and ask them their thoughts.
          looks like you got a swash put together by that new guy they just hired with four thumbs.
          Sponsored by CSM, Optifuel
          Your RC Heli World
            isn't it the new style putty bearings their fitting
            Slow Mo Blade 550x
              Now now...
              Sensible comments please Richie... This is not an Align Vs Compass discussion
              Cheers, Lee.
                now you've done it, thread hijack imminent
                Your RC Heli World
                  I know... All I wanted to know is if it's ok to fly or not. It is err-ing toward to the not
                  I have PMed Bobj to see what he says...
                  Meanwhile, the 500 will sit on the dining room table and look pretty
                  Cheers, Lee.
                    it will fly, just won't be very accurate
                    Your RC Heli World
                      until they part company, then it might be a little sluggish on the response.
                      And a DX8 too
                        Thanks for that Jamez. It's defo staying on the dining room table now
                        Cheers, Lee.
                          Just paint it Blue it will be fine
                          TDR (in progress)
                          SAB Goblin 700
                          Vibe 90SG Vibe 500E
                          Kalt Baron30
                            Seriously Lee
                            you must be gutted to find that on a new heli
                            TDR (in progress)
                            SAB Goblin 700
                            Vibe 90SG Vibe 500E
                            Kalt Baron30
                              I would check the bearing race isn't falling out of that Leebert.
                              If the race is tight in the housing then the balls must be about to fall out!
