550 & Vbar
  • 550 & Vbar
    Is anybody using the blueline mini vbar on the 550e (5.1 pro version)? If so would you mind posting your flie on here so I could use as a starting point. It's not the quick set up info I'm after it's the other parameters I'm intrested in looking at.
    Thanks in advance.
    no point as no two v bar set ups are the same, start at the begining and work your way through them, even i can set them up and thats saying something.
    Troll buster
      I know how the vbar works, I've already got one on my TDR, Just wanted to see what parameters (gains, agility, yaw rate, paddle sim etc etc ) others where using in there set up.
        Always interesting to see other peoples setup files IMHO. Not sure I'd use one as a starting point though even on an identical setup.
        Phil
          Here you go mate.
            Thanks Tim, It'll be intresting and useful to see what parameters you've settled with.
