hmmmmmmmmmmmmmmmm it all depends on what u want it for the 700 is more money and more batteries where as the 550 is less money and less batteries and they pretty much flies the same so i would say the 550E with a beast x
Do what u do best
DX7 and DX8
Phoenix sim
And plenty of spare parts
I have both of these and rate them both highly,the 550E is the best all rounder i think taking everything into consideration.
The 700E is just insane,as to be fair i am sure most well specced 90 electrics would be,power delivery is consistent with good packs and ruthless,blows any 90 nitro i have seen clean out of the water.
Agree also,IMHO the 3g is certainly OK but a something more akin to a Beast X,V Bar etc would give you a better fbl experience.
Having both machines in 3G format I can compare the two quite well.
The 550 is a very nice machine, small, powerful and cheap to repair and run using only one 6s pack. The 700e will ultimately cost a bit more initially, 2x 6s packs to make one 12s for a single flight, then as with the 550 a decent charger keeps you flying through the day with minimal charge times.
Flying wise the 550 I think is more of a hooligan machine, while the 700 which can still be thrown about like the 550 due to its size is much more graceful. As a result, as with any 90 size machine, the 700 looks good in the air and is nice to watch.
However, while my 700 inspires real confidence to push your skills I am more inclined to try new stuff on the 550 first initially, but am finding myself using the 700 more if I feel on the ball on a given day as its very rewarding to fly.
The 3G for me is working well, I have spent a lot of time making them just that little bit better, but out the box they are quite good.
Whichever way you go if you would like I can send you my 3G settings file for uploading to your own model.
Ian Contessa
