After a little crash caused by the pcm on my futaba cutting in and stalling the engine I decided to take the plunge and go 2.4gig.
ive now got the heli setup and ready to go, im a little concerned with where ive placed the mini reciever all ive done at the moment is exchange the pcm one for the AR6100 so its placed between the carbon frames at the back with the wires sticking out a little on each side.
Obviously with all that carbon im concerned with shielding of the signal. Last night I did a range check I was far enough away from the machine not to be able to see it except as a spec and all the controls worked fine, but I am still obviously concerned and wondered if anyone else had used this reciever in this position.
