Pitch and Throttle curves
  • Pitch and Throttle curves
    Today, I am trying to setup my curves. No 3D stuff. Just calm, stable slow flight. So, I'm thinking about this (Graph and details attached). Is there a way to see what my headspeed would be without a tachometer? Also, is this a good curve setting?
    Blade CX2 - With AR6100
    Cralis,
    I'd have a look here.....
    http://www.trextuning.com/setuptrex.php
    Loads of good advice etc. I've just had a quick look at it, bear in mind yours is an SE so not everything will apply, but it's this site that got me off the ground for the first time!
    I'm still a beginner, but the only thing I would change on the pitch curve on the site is to set it so that you have 1 or 2 degrees negative pitch at low stick to help the heli come down i.e set point 1 at about 35 - 40%. That's a personal choice though
    Simon
