I have just watched the Finless video on programming the Align speed controller.
I have the 35A ESC. Not sure whihc 'revision'. It's been sent to get a new connector attached.
I didn't quite understand how to go into Programming mode. Is it just a case of putting full throttle, and then powering up the ESC?
Anyone know where I may be able to download the manual for this?
My understanding is that there are 4, maybe 5 settings.
1. Break.
Not sure what that does, but possibly something to do with cutting the engine for some reason? Finless says leave it disabled for helis.
2. Timing.
Again, not sure what that is, but will leave Mid.
3. BAttery Protection.
Again, not sure. Says to leave at 65%.
4. Govenor.
Finally, what's that!? I heard one of the options is 'Soft Start'. Seems like the safest bet for a novice. Slowly spins up? Then theres Soft Start with Govenor. He (Finless) says to not use the govenor. Why, and what is the govenor?
5. Throttle responce. (Maybe only on newer models)
Going to set that to low. Don't need the kicks, as will be doing hovering.
Could someone maybe help with the meaning of all these, and best settings? Also, is there a PDF manual anywhere?
THanks guys.
1. Break.
2. Timing.
4. Govenor.
THanks guys.
)for setting up
