hitec hs65 which ones??
  • hitec hs65 which ones??
    hi
    going to get some of the hitec hs65 servos for my t-rex which are best the metal gear ones or the karbonite?would the metal gear ones be more robust?thanks
    go carbonite...and in fact if u check classifieds....i have 2 brand new ones for sale.
      Without wanting to stir up a hornets nest, go metal. I had some carbonite geared 56's, the new ones may be strong but very brittle so after every crash you'll be replacing a gear set.
      Clones are bad
      .... that includes Align ones
        dam..
          Tis true but I have had three crashes with my trex. One killed a gear set and the other two didn't. Still, the gear set is only about two quid so it's not all bad.
          Cheers, Lee.
          Proud recipient of an EGS
            actually i trashed the gear on a HS56 how on earth do u get the bearing off the main gear to put onto new replacement gear. i broke the little bearing in the end and had to buy new servo its was locked on i tried prising up pulling off everything..maybe i had a well stuck one????????
              I normally pry them off with a very small screwdriver if you take your time it's quite simple, mind you I've had a bit of practice
              Phil
                Patience and a small screwdriver.
                You need to get it off the shaft 'square' if you see what I mean.
                Cheers, Lee.
                  i dont get u?? the square shaft?
                    The bearing needs to be slid off the shaft as straight as possible. If you try and lever off one side of the bearing at a time it tends to stick on the shaft.
                    Gently prise the bearing with a small screwdriver a little at a time, working round and round the bearing.
                    Cheers, Lee.
                      sorry yes i see what u mean..i did try pulling straight..oh well..next time ill give it a go working way round it.
                      thanks
