Hi
Tried setting up my newly swapped T-Rex 450 XL this evening with some problems.
Charged the Li-Po okay.
Put new crystal into Futaba 146 PCM receiver and Transmitter.
Switched on TX then connected battery in Trex.
I get the three beeps then nothing suggesting that the ESC cannot find the transmitter.
I then realise I've put the TX crystal into the RX and vice versa.
Since then, nothing but the three beeps.
Question,
1. Will this sh@g the receiver and why was I so stupid?
2. What is the difference between a Futaba 35-1 and a 35-10 RX crystal and is this the reason for the problem?
I've tested the TX and crystals on the Shuttle and everything on the TX side is fine.
Any suggestions before I pull the RX out and try with proper batteries etc etc?
Mark
Question,
Mark
