Pushrod
  • Pushrod
    Hi All
    Anyone know where I can buy and carbon tail pushrod set for a 450 v2, googled it but nothing comes up for a 450??
    Appreciate your help
    Terry
    **Trex 450 SE V2
    **Futaba FF7
    **Futaba 7c 2.4ghz
    ARC Ready 2 (trainer)
    Just buy the original push rod and a length of hollow carbon tube, cut it to the right length, put a little epoxy on the rod and push it through. Put your ball links on and your done. Gave my 450 a much more locked in tail :-)
      I bought a set of spare link rods and a length of carbon tube from my LHS and made my own.
      Snarf
      Scale - Aerospatiale SA 315B Lama, Bell UH-1B Huey, Bell AH-1 Cobra, Bolkow BO-105, Hughes 500E
      Sport - Trex 450 SE V2
      JR DSX9 | Cellpro 10s | Phoenix
        I don't know if this is any help, I have one of these as a spare, and I'm sure the rod is carbon, as it has the same strength and feel as the push rod fitted on my 450.
        I also have a steel push rod and that bends like buggery, but the below mentioned rod is very much stronger, and doesn't flex.
        HS1017 : Tail Control Rod Assembly - T-Rex
        http://www.modelhelicopters.co.uk/ac...Sprs_Trex.html
        sigpicWayne AKA OB1
        Plus 3 Eddie Gold Stars, yay!
          Don't know for shure but the Storm push rod might fit.
          http://www.modelhelicopters.co.uk/ac...sterStorm.html
          6602306 : TWISTER 3D STORM CARBON TAIL PUSHROD
          Dean
          Dean
          www.midlandhelicopterclub.org.uk
