Hi All
Just been out in the garden, put a battery thru it and all went well (just starting out, Trex 450 v2). towards end of battery ( I thought) needed more power, changed battery, seems as tho the head is very stiff, will not turn, tried all the servos and they are working fine, when I tried power just would not turn, the tail started to move about, closed down, turned head a bit to tidy up the rotor blades, very very stiff, pinion is ok and turning. main shaft looks ok, anyway I had a battery thru it before it happened??? Appreciate yr help.
