Boom slipping !?
  • Boom slipping !?
    My carbon boom keeps slipping in the 500 and loosening the belt. Its so bad that recently I can't take off ! I have tried cleaning and sanding the boom/boom block, as well as using clingfilm on the boom. Neither have helped. The problems only started 30 or 40 flights after getting a carbon boom. I thought clingfilm would work, as I did it as thick as I could, with it still sliding inside the boom block.
    Any help would be appreciated. I am thinking of removing the carbon boom and putting the old alu boom back in. Seems a shame though if there is an easy fix.
    Oliver Crawford - Align 12S T-rex 600e, Align 610 x3, Spartan 760, tail Align 620, Scorpion 4025-630 KV, Bec pro, Castle Creations HV 80A ice.
    Align T-rex 700e, Align 610 x3, 3g, Spartan 760,Align 650, Bec pro, Castle Creations HV 110A.
    try sellotape or insulation tape
    about half a dozens turns
    mark
    MARK
    LOGO 500 V-BAR v5.2
    GAUI X4ii
    PROTOS 500
    MINI PROTOS 6S (stretched )
    GAUI X3. 6S
    JR DSX12
    14SG S-BUS
    proud owner of 2 x EGS
    www.bmmfc.com
      Two turns of clingfilm made it hard to insert the boom in the block. I could try x6 of insulation tape and use a screwdriver to open up the block while I push the boom in? I want to fly today, so might try a self tapper in the boom to stop it sliding tighter.
        sellotape/insulation tape/masking tape. Or try some hot glue ive heard that works quite well. It wont make the boom non removable too as its quite easy to peel off.
        Lee
        Lee
        www.raptoruas.co.uk
        www.lee.rcha-uk.com
        www.gensace.de
          I had a similar problem on the 450. After advice from this site I purchased another tail servo clamp and placed that against the boom clamp. When tightening the belt I tighten the clamp first then the boom clamp - its easy and works very well.
          Shaun.
          Proud owner of an Eddie Gold Star.
          T-Rex 450 SE V2, Maniacs, Kontronik Jazz ESC, Microheli Tail
          T-Rex 500 CF, DS510's, Maniacs, Torque Tube Tail Drive
          T-Rex 600NSP, Maniac 603's
          T-Rex 600ESP, Maniac 603's, DS610's
          T-Rex 700LE, Maniacs, DS610's, Solid-G/BLS251, ElyQ Reg
          Futaba FF7 2.4 GHz
          Phoenix Sim
            we forgot about that one didnt we,,
              It used to be a common problem with larger machines a few years back.
              The standard mod was to put a small PK (self tapper) screw through the boom holders, so that it just penetrated the boom. (Not too far, or it will damage the belt!)
                Also just to add, if you are going to self tap screw the boom, make sure you drill a clearance hole in the carbon boom, the carbon wont strech like ali, its too brittle and will crack.
                Oli
                Oli
                Raptor 90 and a Raptor 30
