Hi guys...just replaced my belt on my new 450SEv2 as the belt rode up off the pulley and jammed...and it looked a bit frayed!
anyway - my 2 questions are (I bought the 450 pre-assembled RTF so I *really* am a noob!) :-
1. should I be threadlocking all the bolts on the tail assembly? the build manual indicates putting threadlock on the screw that clamps the tail gear case, the linkage ball that connects to the rudder control rod and the collar screw that the tail rotor control arm pivots on....so should I just threadlock pretty much everything? I'm particularly puzzled as to why no threadlock on the other linkage ball (the one that screws into the tail pitch assembly).
2. I've heard people mention they use silicone oil on the belt...I have some 3-in-1 silicone spray lubricant (http://www.maplin.co.uk/Module.aspx?...20oil&doy=18m6) would that be OK?
thanks in advance guys!
Jonathan
Jonathan
