Over the BH I did the chinese weight mod to the tail of my 450, which is mostly trex but for the sonix superframeand a load of otherstuff. The tail mech is genuine align but driven by acarbon rod old style (not sure why the wire is supposed to be better).
tail is 401/FS61BB with stdcurvy ended plastic align blades.
I just got the chance to fly it.
It wagged on piro stop until I reduced the gain to 72% from 82% (on gear end points).
piro rate is up about 50% which I guess is like a mechanical gain increase.
It bounced a lot on piro stop, and now i have a bit of delay (25%) to cure it and performance seems pretty good but darkness and small field size restricted things.
Piro rate seems more constant in a ripper (falling out of a stall turn piroetting), as would be expected if the piro rate has increased purely from the mechanical setup.
so, in my opinion the blade bris should have these weights on as standard.
I used stainless raptor TT balls and tapped the blade grips m2 just outboard of the bearing. Search helifreak if you don't know what the chinese weight mod is.
to cut a long story short, the blade aerodynamics and the weight of the blade grip control arm make the blade grips want to turn to zero pitch when the tail is revolving. these weights want to turn to 90 degrees pitch when the tail spins. Thus they blance those forces out, at least a bit - so less servo power is needed tocontrol the tail.
Even on a 450 the forces making the blades want to go zero pitch overpower a decent digital servo - otherwise why does my heli piro faster with these weights on? So I should get better tail performance, and better servo life.
We will see, but it looks good so far.
