HS65 Horns / Arms
  • HS65 Horns / Arms
    What are the best arms for these in respect to setting them up at perfect 90degrees?
    The ones I have are all cut to a single arm and none match up quite right so need to order some more!
    Can't you fine adjust them using your Tx?
    Gary
    Align Trex 450se With Copterx head
    Fusano Airwolf kit
    Phoenix sim
      Watch out you might of started an arguement here
      Oli
      Oli
      Raptor 90 and a Raptor 30
        oh no not the old subtrim argument coming up is it?
        lol
        Lee
        Lee
        www.raptoruas.co.uk
        www.lee.rcha-uk.com
        www.gensace.de
          I am after horns that are all slightly staggered to get perfect mechanical alignment, I would rather not use sub trim.
            I spent ages on my 450 after switching to HS65MG's after a crash, bought a load of spare arms and still never managed it mechanically
            Phil
              bump, anyone found any better horns?
              Do futaba mini horns fit??
                I have searched all over the place trying to acheave the same but nothing.
                My LHS says they havent seen anything that would fit either.
                I'm like you wanting to eliminate subtrim all together but as Smoothhound says can't manage it on the 450 (as yet)
                  I've just redone my 500 using DS3500G's and not managed it on that either although 1st time I built it I used no subtrim...
                  Have to say I was a bit more anal about the build this time though
                  Phil
