How long before red locktite is set
  • How long before red locktite is set
    My pinion which drives the tail rotor has come off and I have used red locktite to refit it. How long before it hardens and I can fly again.
    Regards as always
    Sooren
    It pretty much goes off instantly...A few seconds should be all you need to wait...
    Trev
    Sent from my PC using Windows 7
    - CSM
    - Midland Helicopters
      For red loctite when used on steel 25% strength is reached after 10 minutes but it takes between 1 and 3 hours depending on temperature to reach 100% strength.
      http://www.henkelna.com/cps/rde/xchg...UID=0000000HX2
      Bottom of the page for the datasheet.
      Member of Mk Heli Club
        Most Loctite (Blue and Red included), start setting immediately they are in an air excluded area (oxygen ?), i.e. on a thread thats been tightened.
        That's why you only ever buy what appears to be half a bottle, the air space stops it setting. This is also why spilt loctite takes a loooooong time to set on the bench, but funnily enough, sets very quickly when sprayed up a magnolia emulsion painted wall !
        Janek
          Carpet also seems to act as a catalyst!
          I wish my 30 was a 50!
            Don't guess how it works or how long you think it takes to set. Just read the manufactures' datasheet and accept they know their own product!!
              When people repair helis at the field & fly right away, I stand well back!
              Cause it takes more than a few mins to set.
              The less you use the faster it sets.
              Tim.
