Is that unlucky or have I a problem with my 450SE v2.
Flew it Sunday morning when the tail belt broke and managed to get it down without any damage, But when it happened again tonight I feel there there must be a problem somewhere, Hence I got it down for a second time again with no damage luckily hitting the hold switch promptly.
Now the belt tension is not too tight (when you nip the belt together it touches no problem) but I fail to see why a second belt has broken after only around 15 packs through it.
Flying idle up every flight with all standard parts as it came new before Christmas. Checked the pulley's/bearings/tail boom is straight/fitted a new tail rotor shaft/Everything is in-line.
The heli fly's absolutely fine with no problems at all but I feel my luck can't last if these keep snapping.
Any thoughts guy's.
Any thoughts guy's.
