trex 550 pro dfc how amd where to mount the esc
  • trex 550 pro dfc how amd where to mount the esc
    Just got my trex 550 e pro dfc with the 700 class motor. I am struggling to work out how to fit the motor and esc.
    I have tried mounting it under the batterry tray but the motor wires are pretty stiff and I dont wamt to damage them by forcing the esc under the tray ans scrunching the cables. I have tried mounting it on the side but I have a similar problem with the motor wires getting caught on the frame, also the battery wires arent long enough. Does any one have any pictures show how they have mounted it? Ive seen pic and videos of the normal one but not the one with the larger motor. Any help would be appreciated.
    Oxy 2 - Spartan VX1n
    Trex 700XN - Spartan VX1n
    Trex 700N DTS - Spartan VX1n
    Logo 690SX - Spartan VX1e
    780L Top - VBar Neo
    2 x 700L Top - Spartan VX1n
    Logo 550SX - Spartan VX1n
    Jeti DS14 BK edition
    DX9
    Pheonix R/C
    AccuRC
    neXt
    Think you just need to ease them wires round to where they need to go, there aren't many other spots to put it. Obviously rub down sharp edges of frame where cables pass through/over but once in place they aren't moving around.
      I had the same issue. Move the wires around gently (but firmly - as if that makes sense) and it will fit.
      I also wrapped a strap around the esc and battery mount as I don't trust just tape holding it in place.
      I had a hell of a time looking at the manual, trying to fit it, thinking this all seems seems wrong but it does work.
      Cuffley MFC www.cuffleymfc.co.uk
      Too many toys to list...
        There is a thread that Coolice put up and I also did the same with mounting the ESC on the side of the heli, you just need a small amount of surgery on the side frame. I like the position as it has some protection and you can rip it off if it starts to smoke.....
        Paul ​
        DX7s .
        PL8 v3.31
        Phoenix v5.0.p
          Here is how mine is mounted.
          good air flow from the canopy hole too and wires are the correct length from stock.
          Can also un clip the esc to remove.
          Proud owner of 3 EGS
            Hey Guys.
            Here is mine. As Paul say you need to dremmel the frames a little to make this work, but it's quite neat and offers a little more protection to the ESC should the model go in nose first.
            The zip tie is then loosely over the top of the ESC to stop it coming out of it's plastic mounting bracket.
            Ian Contessa
            Coolice Power Supplies
              Hey Guys.
              +1 on Ian's post (couldn't find the thread myself, so well done Ian). The only thing I would counsel (having had multiple dealings with CC, don't ask why!!!) is not to use a cable tie to restrain the ESC, as CC frown on that and will try to wriggle in the event of a claim, also by using a Velcro strap you can rip it off the heli more easily & quickly should you need to ;-p.
              I managed to mount mine a tiny bit more left hand down which let me run a velcro strap through the battery strap hole to ensure the ESC stays in its cradle. Totally agree with better protection for the ESC (again, don't ask how I know....!!)
              Paul ​
              DX7s .
              PL8 v3.31
              Phoenix v5.0.p
                Mine ImageUploadedByTapatalk1400578421.219680.jpgImageUploadedByTapatalk1400578435.416807.jpg
                  I thought I would post some pics to show where I placed mine in the end. I did extend the motor wires so that it would fit nicely on the side.
                  780L Top - VBar Neo
                  DX9
                  Pheonix R/C
                  AccuRC
                  neXt
                    I think it's bad idea to put velcro on heatsink of esc.
                      To be honest so did I at first but it seems to be the standard method.
                      780L Top - VBar Neo
                      DX9
                      Pheonix R/C
                      AccuRC
                      neXt
                        If your heat sink gets hot enough to melt the Velcro strap you have bigger problems....... Never seen a problem myself.
                        Paul ​
                        DX7s .
                        PL8 v3.31
                        Phoenix v5.0.p
                          not to use a cable tie to restrain the ESC.................by using a Velcro strap you can rip it off the heli more easily & quickly should you need to ;-p
                          I am 100% with the above quotes. On my 550 it is on the side, in the open.
                          Further, for me, I am concerned about mounting them A) under the battery and B) under the canopy space. Be able to whip it off smartish is my thinking.
