600 pro rate mode setup issue
  • 600 pro rate mode setup issue
    I'm trying to carry out a rate mode setup on my 600 pro
    I have the servo mounted as per the manual, the horn is at 90 too, I ended up buying a few more horns to get it right.
    I have tried to set it up today as per the tuning guide on HF but my control rod both ends of the rod the ball links are screwed in fully now and the tail is still drifting.
    It's almost as if it could do with a further 2 turns which i'm sure would cure it.
    Has anyone else tried it and found a fix? I cant seem to find anything over google either.
    What controller have you fitted?
      [PHP][/PHP]
      It has the ar7200bx fitted.
        Although it's best to do what you're doing I doubt if it's a slight offset it will make too much difference. Although it will help the stops, make sure your piro speed is the same both ways first before you try changing anything else you will find you will have to either drop left piro on the end points or up them on piro right. I've found it needs both but that's on a 600n, points are 95/108. Make sure you redo your limits when you've altered the rod.
