Hi. I'm running a DX7s with stock align 600efl pro running mini 3gx. When I switch between flight modes from normal to idle-up 1, the heli drops slightly and the pitch range is off by around 2 degrees. This in normal mode the pitch range is +12 to -12 but in idle-up the pitch range changes to +10 to -14 ish. Why is this? The pitch curve on both flight modes is the same. The swash mix doesn't change between the two flight modes.
3gx/spektrum advice please
This topic is closed.
The values in the pitch curve norm idle and hold must be different then.for swash to moveOriginally posted by JamieD View Postnope. At mid-stick it drops by a couple of degrees when I stich into idle-up. It also does the same when I switch into throttle hold.Santander Factory Team
Proud wearer of 5 x EGS
nope, the pitch curve graph and the numbers for all flight modes are the same 0,25,50,75,100. The numbers in the swash mix menu stay the same. When I switch between modes, the swash drops by two degrees throughout the entire pitch range. This is also reflected on the DX7s display, you can see the pitch, ele, aileron drop when switching. I can't see any mixing that might be active either.Last edited by JamieD; 23-11-2013, 03:37 PM.Synergy E7SE - Spektrum AR7200BX
Align 600EFL DFC - Spektrum AR7200BX
Align 450 Pro DFC - 3GX
If it changes in the TX too, then you must have something awry in your DX7. What about dual rates or expo?Tom
Travel and trims?
One thing to try is to copy your 600EFL settings into another (completely clean) memory slot in your DX7 and rebind. Sometimes that can be the quickest way to fix obscure problems like this ...Tom
Sometimes the readings the software tells you are not the same as you get. As mentioned it could be a trim problem as trim settings are different for each flight mode. Starting a new memory and reprogramming from scratch may be the easiest way to sort it. I'd check the outputs on the monitor screen.Flasher 450 Sport. Assan GA250 with 520 tail servo, MKS DS450 cyclic.
Blade 130-X, MSR, MSRX
Phoenix Sim
OK I've found it! I had the auxillary knob as pitch adjustment in the model switch settings. De-activated it and now there's no problems :-).
case closed.
Thanks to Horizon for their support.Synergy E7SE - Spektrum AR7200BX
