the life of my 600e rpo , plus align booster vid
  • the life of my 600e rpo , plus align booster vid
    picked this up , cleaned it up , made 3 DS610`s outta 8 bust ones and a DS615 for the tail outta 4 bust ones , will fit a tail servo when possible , and just for the world , align have brought out this booster pack for the pro , cool
    Seaking
    Only seems like a second ago we were brought to the attention of 3GX V3.2 and this vid had V4.0 I wonder what's been update this time around.
    MIKADO VCONTROL
    SCORPION ​TRIBUNUS
    neXt
      When they sped up the vid to show under the canopy i thought his CC speedo was on fire
        well after destroying the 500 yesterday , thought i had better get this one sorted . being skint once more and the fact i owe my local shop for the last 500 smack , i can`t borrow from them again , have put the 500 whats left bits in there second hand cabinet to pay the debt so my only problem with the 600 was a crack in the frame at the bottom of the right hand aileron servo , so out of my bits tub came one of the bits used on the pro flybar`d head , a couple of longer screws n washers n spacers later , its all braced n solid again , no point in buying a new frame till i`ve totaled this one , only now require a pair of batteries and some main blades , got 2 weeks before we can use the field again , so must get busking
        Seaking
          yeaaahhhh , at last we have a field to fly on , ours is still covered in rubbish , so we have the use of our old field for a while , the bad news is , on flight number 7 , the new black tail gears stripped , causing a mega piro into the deck , TH was used but alas , its wiped out
          main blades
          main shaft bearings
          my broken side frame is very broken
          all 3 DS615 servo gear sets
          one HK HV hobbyking tail servo
          boom
          boom supports
          tt
          tt gears front n back , black ones
          main gear
          canopy
          a brand new 30c 3300 li-po
          undercart
          bottoms
          yet another heli passes on
          Seaking
            Thats not Norwich in that video
              Gord knows where align film there stuff , certainly not around here
              Seaking
                Maybe it's time to consider......................... Knitting lol
                  thank you don here`s the wife when i got home -> , will rebuild my 450 soon , aren`t they fiddly little buggers to work on
                  Seaking
