Hi all just a quick one is the standard esc enough to run a scorpion 4025 1100kv
trex 550 standard esc
I would be wary of the Align 100A esc if I were you. I had that setup with the Align 600 motor on my Fusion and the esc literally set on fire and was completely destroyed. I replaced it with the Castle ice2 80HV and that worked much better....until the Align motor blew up! The 550 will be kinder though because of the shorter blades - I was running 600mm blades.Trex 700 DFC - Vortexted, TRex 600, OUTRAGE FUSION 50, 500ESP, 450PRO, 130x.
