fbl ball links?
  • fbl ball links?
    ive just ordered some 700 fbl ball links but the ones that came are the same as the elevator A-arm links, which are also the ones that come with the DFC head.
    I need the normal fbl ball links as they are slightly longer but cant find them??
    Anyone know anywhere that has them please?
    Avant mostro 700E
    Avant mostro 700 Nitro
    member of :
    South cheshire heliaddicts
    quick uk have stock tony,i looked at them at 5pm today,my guess is you can use the longer links if you cut off 2mm for the dfc
    Quick UK Retail - shop-products
      Cheers Nick
      These arent the flybarred links though are they? The fbl links are to fit the thicker rods 2.5mm i think?
      Im actually after a longer link than the dfc link anyway so wouldnt need to cut that few mm off.
      Avant mostro 700E
      member of :
        Did'nt think of that...what about?
        700EFL flybarless Linkage rod(A) set H70066 - Flybarless kits and parts 700 FL flybarless Parts - ALIGN-TREX.co.uk
          You can probably use these direct to arm with short threaded rod instead of the bit with the nut on?
            theyre the buggers nick, cheers Mate
            Avant mostro 700E
            member of :
