Swash movement
  • Swash movement
    Silly one but what way should the swash plate move on adding throttle? So when I'm pushing the left stick (throttle pitch) in what direction should the swash be moving UP or DOWN thanks for any replies
    Just finishing the 600
    RAPTOR 60
    TREX 500 CF, FBL
    MSR-X
    JR XG7
    __________________________________________________ ______________________
    http://www.hdrcmc.co.uk/index.htm
    Whichever way gives positive pitch so blades are blowing dowards (trailing edge down of blades) when the stick is pushed upwards. If it does not reverse your swash mix pitch to a negative number.
      up of course, unless its a century neon blaze
      Santander Factory Team
      Proud wearer of 5 x EGS
        Throttle up swash up simples.
        Trex 450 SEV2.
          It depends on the helicopter configuration if the swash goes up or down. Swash up does not always mean positive pitch. It depends on the linkages, trailing or leading edge etc.
            Bugger ! Stand corrected, humble pie in the oven for me supper. Did intend to edit and add " As long as pitch increases with up stick, but you beat me to it.
            Trex 450 SEV2.
              This is why I ask as on a old heli I setup a longtime ago it would not come off the ground but when I gave less throttle it would start to come in to a hover.
              RAPTOR 60
              TREX 500 CF, FBL
              MSR-X
              JR XG7
                So the heli is a trex 600le
                I should be getting the swash moving up with stick moving up then right?
                RAPTOR 60
                TREX 500 CF, FBL
                MSR-X
                JR XG7
                  Scary stuff, I think we've all seen someone with reversed pitch, at least I have scared the crap out of me as I wasn't looking that way!!
                  The worst thing is when someone adds negative to land, only to have it take off at top speed!
                  If you want to be 100% sure then go ahead and take pictures of the head at both low and high stick then we can say for sure.
                    Or a Mini Titon E325 thunder Tiger
                    GAUI X7 Beast X V3 (a nice bit of fish!)
                    Trex600n Fbl ys56sr BeastX V3
                    Trex500Fbl AR7200BX
                    Trex500 Apache x4bld BeastX. Trex 600E HIND mil x5bld BeastX
                    DX7se
                      It should be upwards if built as per the manual.
                        Throttle leaver down swash down
                        RAPTOR 60
                        TREX 500 CF, FBL
                        MSR-X
                        JR XG7
                          Throttle lever up swash up
                          RAPTOR 60
                          TREX 500 CF, FBL
                          MSR-X
                          JR XG7
                            Good to go, but looks like you have more negative pitch than positive. It might just be the camera mind you!
                            At mid stick you should have 0 degrees blade pitch.
                              I will go over the pitch settings again tomorrow night. Thanks for all replies
                              RAPTOR 60
                              TREX 500 CF, FBL
                              MSR-X
                              JR XG7
