feathering shaft fitting
  • feathering shaft fitting
    hi do you lube the shaft to get it to slide in as i just put 1 in t block and damn it was hard work
    ifso what do you use as lubricant
    thanks terry
    Yes grease as in manual. I use aeroshell 7 or 33 but any grease should do a trip.
    Raptor 50 v2, trex 600n fbl, trex 550 v2 3gx, trex 450 3gx v2, mini-titan v1, mcpx v1, WoT4 foamE, Gootch 450, mcpx bl.
      Make sure you stick a bolt in the side you are pushing in. Stops the grease getting into the thread and stopping your threadlock from sticking
        as per manual sorry i should of known better really to think of that lol 450 never come with manuel but my 600 has but was allready built but i do have the manuel naughty me but thanks for replies
          R u Welwyn Garden ??.
            I lube up the feathering shaft with this Robbe High Performance Grease S1315 its very good grease!!!!!!
              yes mate i am wgc
