Hi all, Just wondered if there was any advantage of 3GX over Beastx on this size heli or vice versa? Or does size not matter here and down to personal preference? Anyone fly trex 250 with 3GX?
FBL controller on 250 size heli
[/SIGPIC]Goblin 700 vbar blueline, spektrum Hv servos|Goblin 570 Red/Yellow, mini vbar pro, BK's|Goblin 500 red, mini vbar pro, scorpion 4020 1100kv, jive 100+,BK's |Goblin 380, xnova 2820, mini vbar, yge 90, quick connect|Trex 450 pro 7200bx & RJX fbl head|130x|ncpx|DX9| BMFA Member|Tags: None
Most of what I've seen BeastX works well on Gaui 200's
Nick
Rave Ballistic FSO Black - Fusion 50 - Goblin 500 - Synergy N5
Skookum SK540 - VBar - 12FG - Pheonix
Planks: Elf, Blaster 3, Orion DLG's - CTH & Raven Flying wings
Heli History: MCX - MSR - Walkera V200D02 - Gaui 550 - Trex 450 Pro - MSH Protos - Gaui 200 - Logo 400SE - Goblin 630
I'm beastx another chap I know has 3GX his tail is rock solid compared to mine but mine is little more stable in hover than his but 3D stuff his tracks much much better then mine also he's got same problem has me the gyro is on the bottom frame shelf & has to use long thin screwdriver down through the gear to adjust the pots.Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
- Flickr Through My Pictures.
Your tail problem sounds like you need to setup better in non heading hold. Know for bad tail if that's not done. Because the mechanical setup helps gyro big time.Originally posted by tourerjim View PostI'm beastx another chap I know has 3GX his tail is rock solid compared to mine but mine is little more stable in hover than his but 3D stuff his tracks much much better then mine also he's got same problem has me the gyro is on the bottom frame shelf & has to use long thin screwdriver down through the gear to adjust the pots.
I use 3 beastx so far and see Ern's 250 go.
That's the neat setup with out the receiver.
I know both of us use a good tail servo and the bigger tail bladesCheers Paul
Citizen #42
Cheers Paul
Citizen #42
I don't have a problem with my tail other than what I mentioned in my previous post (his tail is rock solid compared to mine) got mine setup nice not the perfect of tails but handles all the 3DOriginally posted by Geek View PostYour tail problem sounds like you need to setup better in non heading hold. Know for bad tail if that's not done. Because the mechanical setup helps gyro big time.
I know both of us use a good tail servo and the bigger tail bladesToday's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
x 3
