R clips on the 700
  • R clips on the 700
    I have to admit that I have been too lazy to put the R clips on the canopy when flying my 700n. They can be quite fiddley, especially in cold weather.
    So far I have just flown trim flights and gentle sport flying and have had no problems, but once I get the engine run in, I will fly it harder. Not too hard, because I am not that good, but tic-tocs and flips etc..
    Is it really necessary to use those R clips on the canopy mounts, or will I get away without? It looks like I will be okay, but appearences can be deceptive. Would the canopy come off without the R clips?
    Andrew
    Life's a bitch and then you fly!!
    T-Rex 450 Pro, GP780, R6106hfc
    T-Rex 500 esp, Quark, R6106hfc - For Sale
    T-Rex 600 LE, Metal Quark, OS55, A395, R6008hs, Multigov Pro
    T-Rex 700LE FBL, OS91H, CGY750, BLS451s, BLS251
    SRIMOK 90N cyber conversion, YS91SRS, CGY750, Radix, BLS352s, BLS251
    8FG - Now with 14 channels!
    I can give you half an answer on this!!
    I have got QuickUK Thumb screws on the rear of the canopy, and the standard posts for the R Clips at the front. Never use the R Clips, and never had the front of the canopy lift off the posts yet.
    You should be ok, but i just feel that tad safer with the thumb screws on the back!
    Rgds
    Aidi
    700N 700E 550E
      When I first built my 700 many moons ago, I found that the stock canopy started to crack around the mounting posts after about 5 times on and off with the canopy - I guessed this was down to having to 'stretch' the canopy over the extended posts. I changed to Quick UK posts with thumb screws (no stretching required) and have never had a crack since, after about 4 years.
      JR Vibe Fifty fb (YS56)
        I didn't even think of that side of things, just whether or not it was secure, but now you mention it, I have seen the initial stages of cracking from the beginning. I just took advantage of the Midland sale, blinging the elevator servo mount and putting a tail boom support brace on, but maybe I would have been better off putting improved canopy posts on. Oh well.
          Quick UK magnetic mounts are a one time fix
          TDR (in progress)
          SAB Goblin 700
          Vibe 90SG Vibe 500E
          Kalt Baron30
            Can't go wrong with QuickUk magnetic mounts
            x 3
              RC booya mounts very good. Don't vibrate loose and fall off as my quick thumb screws seem to like doing. Never used R clips on the standard ones.
                I saw a video recently of a 700E lose its canopy. It was inverted at the time and the canopy went through the rotor disc, taking the help down with it. The damage was terrible and it woke me up. Whatever solution you employ (I use QuickUK screw mounts which are okay) make sure its solid.
                Si
                  Rc Booya Quick release mounts.. wihtout a doubt the best, quickest and safest mounts out there.. have them on every heli
                  Eddie
                  Velocity 90 FBL BeastX V3
                  Trex 600 LE FBL BeastX V3
                  Trex 500 EFL Pro BeastX V3
                  Fusion 50 FBL
                  VBar
                  All powered by a DX8
                    If you want that standard canopy on it,,not if you have a trick V2 one... SACK BOY...
                    TREX 600 pro V-BAR
                    TREX 500 V-BAR
                    DFC
                    BLADE 130x
                    DX7
                    PHOENIX
                      Standard canopy is where its at.
                      You need your phone fixing too?
                      x 3
                        If i was you i would not risk flying without the r clips( yes i still use them) .the canopy vibes alot as and may (will) come off!
                        Long live the flybar.
                          im flying very hard 3d with just the original mounts, no clips, about 10 flights and they are still fne, not budged a bit
                          Chris 'CHUNK' Newby
                          ALIGN-TREX.CO.UK team pilot
                          LYNX team pilot
                          SPARTAN team pilot
                          Dx18
                            No R-clips on the four mounts!Oh wow man .
                              I use the r clips, but I have see an very hard core 3d flyer fly standard mounts no r clips for over a year no problems.
                              Chris.
                              Flying most weekends at CMFA - Trex 700 V-Bar, Trex 600n V-Bar, Trex 250 BeastX
