Hi all, need some help deciding what radio gear to put in my t Rex, can anyone recommend anything? Or make?
T Rex 600 nitro radio gear help?
My 600 has, Spektrum AR7000 Receiver (I use a DX7), Align 2-1 Regulator, Align Governor, Align GP750 Gyro, and Align Servo's on Cyclic (610's) & tail (620) and a JR Servo on the throttle. It flys perfectly well for me with this setup
Del
Outrage Velocity 50 N2 FBL, OS55 Powered
-Built and almost ready to fly
Climb-Out
3D Scotland
Proud owner of 2 EGS
Align DS 610 on cyclic, 620 or 650 on tail. Whatever you want for throttle. If your going flybarless then take your pick down to your budget from whats out there, I use a BeastX. If not then consider a second hand gyro, for me it would be the CSM SL720, only problem being it has to go on the back as it doesn't fit under the canopy. Consider using LiFe packs for electrics avoiding a regulator and 2S LiPo. Some for of governor is nice but not necessary. I use a Throttle Jockey Pro from Model Avionics but others work fine.
your budget would be helpful
plus letting us lot know if/what tx you have as to the make or the rx to useHirobo Turbulence D3
1/4 scale Vario Bell 47 G3
1/3 scale Vario R22
2012 LHC Scale Cup Judge
ive just finished building my Vision 50 comp which is simular to the trex 600.
to give you a rough price guide this is what ive fitted in it and paid.
3x Align DS610 servos on the swash (£120 for all 3)
1x sparton 760 tail gyro (i paid £40 second hand)
1x DS620 tail servo (£40)
1x futaba S3050 on the throttle (£37)
1x Align 2in1 reg (£40)
With a futaba 8FG Tx and 6 channel rx (£300)
I dont think youll go far wrong with a set up like this.
I baught all but one items for my heli brand new, but if you keep an eye out you can get some pretty good kit for a good price.Trex 600N DFC
Logo 600SE
Goblin 700
Spektrum DX9
x 3
