As above, the single connection will also be 4mm bannana connectors. 12 awg wiring would be preferrable but not essential, will be used to charge 6x6s 3300mah lipo's at 1c. Can't find one anywhere, might have to buy ec5 version and cut the ends! Please Help, Ian.
Anyone know where I can get charge lead to charge 6x4mm bananna connected batteries?
[/SIGPIC]Goblin 700 vbar blueline, spektrum Hv servos|Goblin 570 Red/Yellow, mini vbar pro, BK's|Goblin 500 red, mini vbar pro, scorpion 4020 1100kv, jive 100+,BK's |Goblin 380, xnova 2820, mini vbar, yge 90, quick connect|Trex 450 pro 7200bx & RJX fbl head|130x|ncpx|DX9| BMFA Member|Tags: None
Battery connectors are 4mm bannana, and 4mm bannana to the charger, so no deans. The only lead that comes close is this one IC-WEC5 : EC5 x6 Parallel Cable Silicone Wire at Midland: Midland Helicopters Ltd NewItems_NewItemsOriginally posted by cjcj1949 View PostNot sure I fully understand. Won't you be using a balance board? Deans to 4mm can't be that difficult.
But instead of ec5's I need 4mm bannana connectors on all ends.[/SIGPIC]Goblin 700 vbar blueline, spektrum Hv servos|Goblin 570 Red/Yellow, mini vbar pro, BK's|Goblin 500 red, mini vbar pro, scorpion 4020 1100kv, jive 100+,BK's |Goblin 380, xnova 2820, mini vbar, yge 90, quick connect|Trex 450 pro 7200bx & RJX fbl head|130x|ncpx|DX9| BMFA Member|
Many thanks Mark, this will do nicely![/SIGPIC]Goblin 700 vbar blueline, spektrum Hv servos|Goblin 570 Red/Yellow, mini vbar pro, BK's|Goblin 500 red, mini vbar pro, scorpion 4020 1100kv, jive 100+,BK's |Goblin 380, xnova 2820, mini vbar, yge 90, quick connect|Trex 450 pro 7200bx & RJX fbl head|130x|ncpx|DX9| BMFA Member|
No not yet, I'm looking to get a cell pro pl8 with parallel boards, seems to be the most future proofed charger on the market and good value for the next 5+ years. I just sold my Schultz chameleon and 200 watt psu which lasted me the last 8 years. Cell pro boards are fused I believe also so safer than most. What lead were you going to recommend?Originally posted by cjcj1949 View PostDo you have a lead for the balance connectors?[/SIGPIC]Goblin 700 vbar blueline, spektrum Hv servos|Goblin 570 Red/Yellow, mini vbar pro, BK's|Goblin 500 red, mini vbar pro, scorpion 4020 1100kv, jive 100+,BK's |Goblin 380, xnova 2820, mini vbar, yge 90, quick connect|Trex 450 pro 7200bx & RJX fbl head|130x|ncpx|DX9| BMFA Member|
The parallel boards have the sockets in them for both charge current and balancing. Using leads is another way to do it. I don't know if people who use leads bother with balancing.Flasher 450 Sport. Assan GA250 with 520 tail servo, MKS DS450 cyclic.
Blade 130-X, MSR, MSRX
Phoenix Sim
