Hi i am new to the forum just wondered if anyone would be interested in my progress so far. i fitted engine and 3gx about 3 weeks ago had about 6 tanks of fuel through now so on next outing will start to take main screw in to lean off and will post again on my views of peformance. ok now on to 3gx i first found it was way to sentive set on normal so messing around in software i first turned it down to normal gains then added -10 expo using futaba 10c. next flight elevator gain was still to high so turned both alie and elev gains down on pots. i have slight wag in tail but from experiance with 3g unit once the engine is set head speed and pitch is right this should sort alot of it.i was running 8 channel reciever but now this week have changed to s-bus r6203sb reciever to cut down on wires also 8 channel spare for something new lol
. i will hopefully get out this week running and do some more setting up and will repost soon cheers
