Is it just me that thinks the TREX 700 start shaft is a bad design? The other day I went to start it and the starter cup just spun on the shaft. Of course I tried tightening up the grub screws but couldn't align then with the dimples on the shaft so had to give up. (you can easily align the grub screws with the dimples in terms of the angle but not the length of the shaft)
So today I swapped out the whole start shaft for a new one, removing the engine and making double-sure that the grub screws aligned with the dimples. That was a pain in the A to do. First attempt to start - the cup spun on the shaft again.
I genuinely think that the dimples on the start shaft need to be bigger as the grub screws have no real chance of making a strong engagement. The Raptor 50 start shaft is much meatier and a far better design for getting a solid join. I'm tempted to take the Dremmel to the shaft and make a better flat for the grub screws but the shaft is pretty thin and I'd hate to weaken it further.
Do any of you guys have any experience in this area to share? And what's the best way to assemble the start shaft: engine out, or take the clutch stack out the top of the heli by parting the frames slightly?
Si G
Si G
x 3
