Which is the best position for the Beastx is it ok on the front gyro mount or is there less problems if it is mounted on the tail drive box and run extention leads through the frames does it need to be strapped down in either position
Beastx position on 600
Mines on the gyro plate.. not strapped and runs great
There are other members who prefer a denser gyro pad and strapped down though, which I have done on the 500, so will give that a try to see what difference it makes on the 600.. I also have it up front on the gyro plate on the Velo90 but the feckers still got to fly!
Eddie
Velocity 90 FBL BeastX V3
Trex 600 LE FBL BeastX V3
Trex 500 EFL Pro BeastX V3
Fusion 50 FBL VBar
All powered by a DX8
I haven't got one on my 600 yet, but I will be pulling the Gov from the front gyro mount and strapping it to the radio tray, and putting the BeastX on the gyro tray.Harry
Powered by Futaba 18SZ
got mine on the front gyro plate, no strap but mounted on 2 pieces of stiff ripmax double sided sticky foam pad
not flown it yet thoughNick
Henseleit TDR 2011 VBar 5.2, Avant Aurora, 700N BeastX, 500 BeastX
Member of Byley MFC & South Cheshire HeliAddicts (www.southcheshire.rcheliaddict.co.uk)
Mines on the front Gyro tray, use the white sticky tape that comes with it - remove the centre section for Nitro
Raptor 30V1 Maverick Head
OctoCopter
Futaba 14SG
