Head Setup Linkage Lenths Etc
  • Head Setup Linkage Lenths Etc
    Hi all hoping someone can point me to a good head setup link, I'm using the std manual settings and although they work Ok there are issues.
    for example at neg pitch the swash will hit the mast locking collar and bearing block if u use full aileron or elevator.
    jason
    DMHC = Nice place to fly!
    MyPhotoBucket
    mmm what shall I buy next
    you could try lengthening the links from the bell cranks up to the swash then readjusting the ones above the swash to bring the pitch back in line
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
      I always take the push rod lengths in heli instructions as a good starting point, but not as gospel. They are a good guide, but I've almost always then gone on to fettle with them to get everything absolutely bang-on.
      JR Vibe Fifty fb (YS56)
        yep will do chap's thxs
        MyPhotoBucket
          Jason
          Align increased the length of the links up to the swash by 2mm i think in the latest manuals,,my 600N Pro fouls a bit but with the longer links its fine
          I have fouling at all with either of mine now
          Running minus 12 degrees but could get more but would have problems then
            On Daves build, he lengthened the links up to the swash as it was binding at full negative and full cyclic (and still needed more cyclic for decent 3D response).
            | 3D Championship
              so can one of u vernia one of your bell arms to swash for me end to end not center to center so i can see if mine are the short ones or not
              think that makes sense
              MyPhotoBucket
                hum watching the thread with intrest...
                I am just making sure everything is to 90 degress as I can get it. I have one issue though.. I am using metal servo horns and they do not quite go 90 degress but the arm they link to I have made sure thats 90 degress.
                I don't have any plastic servo horns left at all so goto use the metal ones.
                Tail next anyway... Wendsdays job I think....
                Mark
                www.uavaerialservices.co.uk
                BNUCs - Operations certified
                CAA - Permit for Aerial Work
                  its gotta be right boss because if you get differential throw on ccpm it'll do strange things
                  cheers Lee
                    Well oh bugger then
                    I'll source some servo horns...
                    Dam it all
                    Mark
                      Disc just use subtrim to center them or phone Andy at Real Raptors and order a pack of 4x35mm discs at less than 3 quid delivered if i remember.
                      MyPhotoBucket
                        Well oh bugger then
                        Dam it all
                        i have some futaba arms here somewhere.. better to do what arky said and get some of the large futaba discs because you can drill them where you want and get it spot on
                        cheers Lee
                          You seem to forget its me were talking about.....
                          Mark
                            Well oh bugger then
                            Dam it all
                            What you on about?????? It'll do strange things anyway after disc has put it together!!!! LOL
                            Sorry couldn't resist!!!!
                            www.lincsheli.com
                              Er like you enjoyed flying the Titan.. Oh wait no that was after you tweaked it
                              Mark
