sorted, yee harrr
  • sorted, yee harrr
    finally sorted out my wagging tail on the 700. re stipped all the tail down, cleaned everything reassembled making sure threadlock went where it was needed, fitted a carbon tail rod and reamed the ball links to match the balls perfectly, now the tail is soooooo smooth in action its perfect. the other issue was the 3g unit was kicking the swash over on spooldown, i've done the mod on this so abit confused. i tried strapping it down but this didn't help so i stuck another pad under the senser and hey presto its bang on. nearly flys as nice as the 550
    Glad to hear it chap....saves me a trip over then ??
    The 3G units can be sensitive to different pad combinations. If you have found one that works, stick with it.
    Simon
    Trex 700N & E
    x 2
