700N FBL head problem
  • 700N FBL head problem
    Hi Guys
    I have just got my FBL head from fast lads today and i have been sitting here putting it together on my 700N but have come across a problem the box clearly states 700 nitro fbl head kit
    Well the link rods that come with the FBL head kit are to short there 83.5mm but bec i have the standard main shaft (as you do with the 700N) then these are to short, what should have been in the kit as well are 71mm links.
    Whats bugging me is i dont want to have to buy new main shafts just bec the links are to small and fast lads not list the a short main shaft for the nitros nor longer 71mm links
    Iv seen that most people when they buy this kit, it comes with the 71mm links not the short ones and a good friend thought maybe i have the kit for the 700E but as stated above the box clearly states 700 nitro and on fast lads it states it for both Elec and Nitro
    Well now what?
    has anyone out there changed there main shaft to the shorter one and you had to change your links to the small links and you have the long ones as spare??
    Really could do with some if anyone got any or any advise please
    stevie
    MK HELI CLUB WEB SITE
    I'm a bit confused, do you have a standard shaft or the new short version ?
    why are the 83.5m links to short ?
    I don't think I understood your post Stevie, you wouldn't change the shaft you would just get different link rods, just a few pence each.
    Can you clarify the problem ?
    Raptor 30V1 Maverick Head
    OctoCopter
    Futaba 14SG
      Mine is setup with the standard main shaft and agree the links are all but too short but.!!!!
      Just managed to get the correct parameters without buying the latest "shorter" main shaft or links.
      You sure you can't get it there Steve.
        Sorry about that, right i dont have the short main shaft but the links that come with my FBL head are 63.5mm long and thats to short for the standard main shaft,
        I cant find anywhere that sells the longer links 71mm
        i know i can wind the ball links out to get the right size but only get about 5mm of thread in to the ball links and i dont want to risk it
          Hi mate ive just had the same problem, there is two ways to fix,fast lads sell adjustable turnbuckles in a four pack for about £8 which are slightly longer and leave much more in the ball link, if you use these you will need two spare plastic ball links as two are left hand thread and two are right hand thread.
          second way is shorter 700e main shaft, ive got two here and just ended up using the links, can stick one in the post to you if you like,
          if you cant find the turnbuckles i will get the part no when i get to work and send it over,
          hope this helps
          Kasama Srimok, Bls451, Bls251, Gy520, Multigov Pro
          Trex 700n, V Bar 5, Bls251, Ds8911, Multigov Pro
          Trex 600 esp fbl, scorpion, turnigys
          Trex 250, GP750, scorpion, turnigys
          www.kentkopters.co.uk
          1 EGS
            Dave posted about the same problem a couple of days ago. Ended up buying the new mainshaft.
            x 3
              Yep put the short shaft on it last night and job done, imo there is not enough tread using the rods on the normal shaft to safely use the model.
              Plus it looks wicked
              Gaui X7 Formula Vbar
              500 Pro Vbar
              Trex 450 L Dominator Vbar
              Oxy 3 Kbar
                It doesn't help you Steve but it's obvious that Align want us to use the shorter mainshaft with the fbl head and hence the links have been shortened to suit. Why don't Align either advertise the fact or even better FL suggest that you need it the new shorter main when you order the head. This is the 3rd or 4th post on this.
                Flybarless Steve, fair play, BeastX?
                  If this kit is a flybarless conversion set then surely it should come with the shorter shaft as part of the kit! Kind of makes sense to have a kit that has all you need to complete the conversion
                  VIC.
                  JR DSX9
                  TREX 600E
                  Century GL450SE now an Align Airwolf
                  Robbe schluter Jet ranger futura 111
                  Planks.....Chris Foss Phase 6... Sebart Sebach 342 30E.......
                  natures helicopters have the best HH gyros...... sigpic
                    Hi,
                    The shortened main shaft for FBL can be found here:Fast Lad Performance
                    The thicker Align link rods for use with FBL: Fast Lad Performance
                    Thanks!
                    Rossco
                    Equipment for Sale:
                      I agree with all you guys its stupid, esp that short main shaft says its for the 700E and says nothing about using it for the nitro.
                      Also the instructions that come with the FBL kit says the short main shaft is OPTIONAL!!
                      Not a MUST
                      Il say one thing does look nice with less parts
                        Usual Align!!
                        FBL machines usually fly better when the head is closer to the main body anyway so i would probably just buy a set of FBL mainshafts and be done with it! It will make the machine fly better and also makes things easier on you for setting up and also repair later on as you wont be scouring the country for link rods.
                        Also, Am i missing something??, the rods you have are 83.5 and you want some longer ones at 71mm??
                        Happy Flying! Thanks - Dave
                        Sponsored by my own hard work and my good friend's Visa & Mastercard.
                        GAUI NX7 / OS105HZ-R / Powerboost Pipe/ Spartan Vortex VX1N
                        GOBLIN 770 / Scorpion 5025-440 / YGE160 / Spartan Vortex VX1N / GensAce 14S Baby!!
                        Curtis Stingray500 - FPV Pylon racing
                          Originally posted by ROSSCO View Post
                          Hi,
                          Those rods are the shorter rods there not the longers ones i need thanks anyway
                            As Vic has said, its hardly a conversion kit if you then have to go and buy something else in order to be able to fit it, something that is quite crucial to the conversion!
                            Synergy N5 -BeastX
                            450 Pro -BeastX
                            Black Horse Sukhoi 31
                            DSX9
                            Eagle RC Heli Club
                              I agree its stupid or put at least both options in the box short link and long links
