Looking to buy T-rex 600
  • Looking to buy T-rex 600
    Looking for T-rex 600.
    My first heli..prefer package with batteries /Radio gear.
    Also simulator..
    Thanks.
    May consider 450
    check www.align-trex.co.uk
    mark
    3x700s none mine
      Erm.. how about here Fast Lad Performance you've got plenty of choices!
      So are you wanting electric/Nitro.. new/used? Do an introduction on new members mate and post more detailed description off what you want/advice as you'll probably get more replies that way
      Eddie
      Velocity 90 FBL BeastX V3
      Trex 600 LE FBL BeastX V3
      Trex 500 EFL Pro BeastX V3
      Fusion 50 FBL
      VBar
      All powered by a DX8
        danny has one for sale
          i know of a very very nice trex600 for sale but it has no tx so you'd have to get one seperately. pm me if you want details and I'll put you in touch with the seller.
            are you looking for new or used
            Sponsored By
            Goblin 500-V bar T-rex700N with FLYBAR.
            http://www.lindensmfc.co.uk/
              Looking at builds and set-up videos on Youtube has put me off a little buying new and building my own.
              Built RC car's in the past though.
              Thought a used electric would be the way to go..
              I'm in Warrington, Cheshire..prepared to travel though.
                Dont be detered by building yourself. If you have built cars in the past, then you should not have a problem with a heli. It really is quite a simple process.
                If you go for a Trex 600, then nearly every conceivable build problem has been asked and the answers are always only a few clicks away!
                Also, in my experience, building yourself gives you a far better insight into how it works and how to fix it when it breaks!!
                Good luck with your search.
                Rgds
                Aidi
                700N 700E 550E
                  Don't worry about the build.. The kit itself is so straight forward and easy, you can shake the box and it'll be built!
                  And as already mentioned, not many problems but were only a few clicks away for any type of help
                  Eddie
                  Fusion 50 FBL
                  VBar
                    Manaul has clear easy to follow build instructions & where here to help.
                    • Flickr Through My Pictures.
                      I've just built my first Trex 600 although I had built Helis' before, I was given a reference to Finless Bob video's on Helifreak and whilst a little american in style, they were very helpful and full of valuable hints.
                      And your going to smack this thing at some point, if you know how it went together it will really help you repair it. Really it is only as complex as a car and no more, bit different and the help on this forum is ace, brillaint and first class.
                      And also whilst most people are genuine any used heli has the unknown factor even to its owner, at least with new, you know its good!
                      Hope that helps!
                      Gaz
                        Trex
                        Hey thanks Gaz..
                        I hear yer bro
                          TRex 600 is a pretty straight-forward build - lots of vis [courtesy of Bob White of Helifreak] and a wealth of experience on here with them. Building bit yourself will give you a great insight into the heli and how it ticks, plus the knowledge that you will be able to fix it when you plop it in.
                          Mike
                          TRex 600NSP, OS55, MicroBeast
                          TRex 500ESP
                          Futaba 14SG Optifuel 20%
                            Thinking..T-rex 450 for 6 months plus sim..then a 600 .
                              OK how about a 500 or 550 then!!!!!!!!!!!LOL
                              Mike
                              TRex 500ESP
