DX8 Telemetry
  • DX8 Telemetry
    Hi has anybody managed to get the Align HE50H22 Governor Sensor working through the tm1000 to show the RPM on a DX8?
    I have installed a seperate one of these on my Trex600N but is does not want to show the RPM. The voltage and Temp show fine.
    Trex 250se 3G, Trex 450Pro 3G
    Trex 500esp 3G, Trex 600nse 3G
    Airwolf (Trex 500esp Helicommand),
    mSR, mCX, DX6i, DX8, Phoenix Sim
    Yep used it from day 1 works well
    Obviously you have the sensor mounted to sense the clutchbell yes ? And you have set the gear ratio on the radio ?
    Sent from my iPhone using crapatalk
      am using this one and its works perfect http://www.fast-lad.co.uk/store/spma...t-p-12621.html
      Do what u do best
      DX7 and DX8
      Phoenix sim
      And plenty of spare parts
        hey am running the rpm sensor but i never set the ratio in the radio and i have no problems have u set urs and is there a difference
        Do what u do best
        DX7 and DX8
        Phoenix sim
          Well how would the radio know what head speed your running as it's not geared 1-1 :0) yours must be telling you your engine rpm !! ;0)
            Dx8 telemetry
            Are you saying you can show head speed rather than engine rpm, how do you do that in the transmitter?, a Trex 600 is 8.5 :1
            Mine shows engine rpm with no problem
              It's in the telemetry settings like I have said I use the align sensor as I have an 7100r revlimiter and I don't really have room for 2 crank sensors
              so mine readings are from the clutchbell !!:0)
                Mines set to 1:1 at the moment, it should be triggered by a magnet on the fan housing.
                Could be a problem with the sensor.
                Is there an easy way to test?
                  My settings above are for my 700 n
                    Dx8 telemetry
                    Wow, thanks for that, did not know that it could be displayed in that format
                      Aren't the trex 700's 8.2:1?
                      Thats what's in mine
                      Cheers Paul
                      Citizen #42
                        yes they are
                        Do what u do best
                        DX7 and DX8
                        Phoenix sim
                          so 8.02:1 is wrong are you saying it should be 8.20:1 ? then as i have taco'd my head and it was spot on ???????
                            just reloaded my 700 settings from the card and it would seem it was 8.20:1
                              D'oh
