I am about to fit my ATGV3 sensor to my 600 heli. Does everyone fit theirs on the inside of the frame or outside? It looks to me that the better fit would be on the outside as it lines up with the slot in the fan shroud.
600 Gov sensor fitting.
To add to my original question, how critical is the alignment of the sensor over the magnet? The reason I am asking is because after fitting the sensor it does not cover the entire magnet (just about half), however the light on the ATG goes on and off when the magnet passes the sensor when turned by hand. Will this be okay or will it lead to problems in use?
on the out side as long as you get your led to come on and off you will be fine. my sensor is a bit off never had a problem with it.Trex700E
sold
Dragons450 gy401 s9257
Mcpx
JRDSX9MK2
coolice Power Supply
I just used an Align sensor with my ATG, works a treat
, then you can use the Align holes on the frame, and fan shroud.
You have to swap two wires (can't remember which two), but PM me is you want to take this route.
Chris.Last edited by CChris; 06-10-2010, 10:05 PM.Flying most weekends at CMFA - Trex 700 V-Bar, Trex 600n V-Bar, Trex 250 BeastX
