Nose diving
  • Nose diving
    Anybody got any ideas why my 600 in forward flight likes to nose dive
    But in the hover its spot on i can almost take my hands off the sticks any help would be appreciated
    Cheers Paul
    Avant Aurora fbl
    Synergy N9 ys91srs
    Paddles out of alignment maybe or centre of gravity.
    But also, hovering trim and flying trim are seldom the same - that's why your cyclic trims are not common across all flight modes. You trim each flight mode independently, so trim each one for the type of flying that you do in that mode.
    A big, flat, solid horizontal fin will also help - the downwash from the main blades will push down on the tail.
    JR Vibe Fifty fb (YS56)
      its always been spot on in both hover and ff i've never been able to get it right since a crash about 2 month ago, centre of gravity is ok and the paddles i lined up with the bottom of the main blade grips with a pitch gauge so they should be level
      Cheers Paul
      Avant Aurora fbl
      Synergy N9 ys91srs
        are those any super-ultralight paddles, by chance?
          If that was the case, wouldn't the heli roll to the left due to gyroscopic precession?
          Life's a bitch and then you fly!!
          T-Rex 450 Pro, GP780, R6106hfc
          T-Rex 500 esp, Quark, R6106hfc - For Sale
          T-Rex 600 LE, Metal Quark, OS55, A395, R6008hs, Multigov Pro
          T-Rex 700LE FBL, OS91H, CGY750, BLS451s, BLS251
          SRIMOK 90N cyber conversion, YS91SRS, CGY750, Radix, BLS352s, BLS251
          8FG - Now with 14 channels!
            Its has the align white carbon fiber ones fitted
            Cheers Paul
            Avant Aurora fbl
            Synergy N9 ys91srs
              Head dampers?
