Head slop on the trex 600
    Wouldnt worry about it too much, it wont fly any straighter
    ...unless you go FBL
    Flybarless combo 600 - AutoPilot & V-Bar
    x 3
      Flybarless*combo*600*-*AutoPilot*&*V-Bar
      I've almost finished my rjx/beastx fitting.
      I'm impressed with the rjx head..considering how cheaply I got it. Rock solid, slop free, stunning finish.
      I've just got to play around with servo horn sizes and position the swash/swash driver and finalise the beastx setup...then go try it (assuming the rain ever stops)..
      If Beastx works anything like it does on my 500 then this combo with a YS56 is going to have more Oomph that my skills will need..
      PGK
        Ok. So.
        I took a set of digital calipers to everything, including some new bits and found that it's just the tolerances that align work to. I'm just amazed that I didn't notice before.
        I've put some bearing fit between the headblock and mainshaft and tightened up the Jesus bolt as tight as I dare. That seems to have removed that issue for he moment. Between the bearings and the mainshaft I did try bearing fit but it didn't work for long. .
        Thanks everyone for the advice.
