Tail interaction
  • Tail interaction
    Hi people,
    need your help on this one, my trex nitro super pro has a strange tail interaction. Running a gp750 gyro mounted at the front and in fast forward flight it tracks true. The problem happens when you pull up into a loop it climbs straight, comes over the top ok then turns left!!!!??????
    I get the same problem if you flip it inverted. Got rid of swash interactions with full climb outs right side up & inverted but cannot stop the tail turning?
    Thought if was me but the 500 racks true, any ideas?????
    wonky thumb
      Thats what i thought, but tried the trex 500 & blade 400 with no problems. Could it be the gyro (gp 750)
        turn the gain up abit higher? what tail servo u using??
          Ds620 had it at 65 & increased it to 75, no change
            is that in the atv or gyro menu????
              Using a dx7, on the gyro sense menu, 35 for non head hold & 75 in heading hold. Gyros at the front do you think moving it to the back would help. Its stange as it only happens when going inverted, loop, flip or rolls
                whach it up higher lol
                  it could be a vibration problem. I once had the same on a 450 with a Logictech 2100.
                  Only in inverted hover it was drifting badly.
                  I'd have a look at the main shaft bearings. I don't think it's a likely explanation, but check anyway...
                    Cheers for that, will check them and try another set of gyro pads
                      What blades? Could be a phasing issue.
                        Still using the set that came in the kit, align 600d carbon fiber
