600 throttle curve
  • 600 throttle curve
    Its another one of those threads .
    I need some throttle curves for the 600 if possible please.
    Im not running a gov yet
    I have the 600 pro with OS50 for power
    I would like a normal curve and a 'V' curve.
    No doubt ive left something out so if you need any more info then please ask .
    Hi mate,
    Can't really comment on the curves as such because my heli runs different gear ratios so it wont mean anything.
    But a couple tips maybe, adjust the mid points to give a smooth power delivery but avoiding over speeding on decents.
    And you will benifit greatly from cyclic to throttle mixing effectively acting like a gov when you load the head with cyclic/pitch.
    Alex
    Innovation RC Blog
    Innovation-Rc on eBay
    www.heliharry.co.uk
    www.robochallenge.co.uk
    500 ESP. Ely Q Comp, KASAMA'd 600
      try this as a starting point but find someone with a tacho or buy one and just tacho the headspeed you want and adjust the throttle curves to your tacho at mid stick on the floor and then in the hover...
      normal mode 0,23,48,63,100
      idle up 100,63,48,63,100
      you can never give an exact number as its depends on servo and arm length and radio used , but above is a starting point and work from there till you get it sorted ... hope this helps
      Knight 3D
        i've got - normal mode 0-19-28-35-42-55-84
        idle up is - 80-60-55-42-52-55-80
        thats on a futaba 10c radio
        Cheers Paul
        Avant Aurora fbl
        Synergy N9 ys91srs
          Yep thts all fine guys I just needed a starting point as mentioned my mate has a tacho but I just needed something to start with as I didn't want to over rev the engine :/. Thanks for the info guys.
            I had 0,40,100 on my 600 with a 50 Hyper for normal mode and 100,40,100 for Idle Up.
