T-Rex 600 NSP Setup help please :D
  • T-Rex 600 NSP Setup help please :D
    Ok so Ive thrown the 600 together, I'm using a Quark gyro and Align Governor with a specktrum AR7000 receiver. Running off my DSX12
    Can anyone tell me what channels they are using for the gyro and governor? Ive got the gyro on the rudder channel and the gain on Aux 2
    Ive got the governor on Throttle and the gear channel and I intend to link it to the idle up switch.
    Anyone clarify the setup for me please?
    ONE Eddie Gold Star!
    Kinross Radio Model Flying Club
    Hey
    Your all backwards on the channels there bud,
    You want the Gov into Throttle and its gain wire into AUx 2
    The gyro into rudder and its gain wire into Gear
    You then need to mix Aux 2 to Aux 2 for the Governor to work
    And you mix gear to gear to use the end points to adjust gain or Gear to Gyro 1 'to use the gyro sense menu to adjust it.
    Hope it helps.
    Alex
    Innovation RC Blog
    Innovation-Rc on eBay
    www.heliharry.co.uk
    www.robochallenge.co.uk
    500 ESP. Ely Q Comp, KASAMA'd 600
      Cheers thanks for that, I remembered the DSX12 Manual has the idiots guide to setting those two up so Ive sorted that and thanks again for your help, you are indeed correct
        No Worries, your welcome
        Alex
        Innovation RC Blog
        www.heliharry.co.uk
