On my trex 700le i have fitted the main shafrt and there is some vertical play. i fitted a washer on the shaft as per the manual, ( i had to use the thinest one as if i use any of the others i can not attach the gears as the holes wont line up
) I am right in thinking there should be no play at all?
Any sugesstions?
) I am right in thinking there should be no play at all? Any sugesstions?
