700LE and Fastlad bolts
  • 700LE and Fastlad bolts
    I am just setting up my head on the 700LE and the rear cyclic bellcranks foul on the fastlad washers and bolts.
    What has everybody else that has used these bolts done? just put the align ones back in?
    TIA
    Mark
    I used the normal bolts which came with kit
    mark
    3x700s none mine
      Now it wont match
        Not matching is better than the servo rod fouling the bolt and crashing your heli.
        It is a fact you have to use the standard Align bolts in the rear holes.
        I don't loctite mine so the buggers come out easier when needed.
        Not as written in the book but better when they need removing.
          What screws are you using ?
          TDR (in progress)
          SAB Goblin 700
          Vibe 90SG Vibe 500E
          Kalt Baron30
            These
            Fast Lad Performance
            but in silver
              YUP...like Tim said.....I found the same problem.....its a pain really
              Ken
              "Yes it is hard to fly"
              "What do you think.....no you carnt have a go"
              "Further than you can see"
              "So your dads got one.....id love to see it"
              Powered by pure luck and a
                I also used the normal ones in that location. I did see someone who dremeled the bolt heads so that they were shallow enough not to foul the bellcrank but I'd say that would make it very easy to strip the bolts when unscrewing them, thus defeating the point of changing the bolts in the first place!
                  I used the Lynx bolts. No such problem with them.
                  Ian
                  Knight 3D
                  Velocity 50
                    I used the Li ron ones before and dont recall having that issue.
                    Got a set on its way for this 700 so will let you know
                      Thanks Ian
                      That was going to be my solution as well
                      These
                      TDR (in progress)
                      SAB Goblin 700
                      Vibe 90SG Vibe 500E
                      Kalt Baron30
